ADM2486高速半双工iCoupler隔离RS-485收发器数据表
消耗积分:0 | 格式:rar | 大小:0.47 MB | 2017-09-29
分享资料个
  The ADM2486 differential bus transceiver is an integrated, galvanically isolated component designed for bidirectional data communication on multipoint bus transmission lines. It is designed for balanced transmission lines and complies with ANSI EIA/TIA-485-A and ISO 8482: 1987(E)。 The device employs Analog Devices iCoupler® technology to combine a 3-channel isolator, a three-state differential line driver, and a differential input receiver into a single package. The logic side of the device is powered with either a 5 V or a 3 V supply, and the bus side uses an isolated 5 V supply.
评论(1)
发评论
syrg 2020-05-24
1 回复 举报
哈哈哈哈或或或或或或或或或或或或 收起回复
下载排行榜
全部1条评论
