2通道与I2C兼容的12位ad7992模数转换器10引脚MSOP封装接口
消耗积分:0 | 格式:rar | 大小:0.67 MB | 2017-10-10
分享资料个
  The AD7992 is a 12-bit, low power, successive approximation ADC with an I2 C-compatible interface. The part operates from a single 2.7 V to 5.5 V power supply and features a 2 µs conversion time. The part contains a 2-channel multiplexer and trackand-hold amplifier that can handle input frequencies up to 11 MHz. The AD7992 provides a 2-wire serial interface compatible with I 2 C interfaces. The part comes in two versions, the AD7992-0 and the AD7992-1, and each version allows for at least two different I2 C addresses. The AD7992-0 supports standard and fast I2 C interface modes, and the AD7992-1 supports standard, fast, and high speed I2 C interface modes. The AD7992 normally remains in a shutdown state while not converting, and powers up only for conversions. The conversion process can be controlled using the CONVST pin, by a command mode where conversions occur across I2 C write operations, or an automatic conversion interval mode selected through software control. The AD7992 requires an external reference in the range of 1.2 V to VDD. This allows the widest dynamic input range to the ADC. On-chip limit registers can be programmed with high and low limits for the conversion result, and an open-drain, out-ofrange indicator output (ALERT) becomes active when the conversion result violates the programmed high or low limits. This output can be used as an interrupt.
评论(0)
发评论
下载排行榜
