双电流输出的并行输入16/14位乘法DAC与四象限电阻器ad5547/ad5557数据表
消耗积分:0 | 格式:rar | 大小:0.39 MB | 2017-10-13
分享资料个
  The AD5547/AD5557 are dual precision, 16-/14-bit, multiplying, low power, current-output, parallel input, digital-to-analog converters (DACs)。 They are designed to operate from single +5 V supply with ±10 V multiplying references for 4-quadrant outputs with 6.8 MHz bandwidth. The built-in, 4-quadrant resistors facilitate resistance matching and temperature tracking, which minimize the number of components needed for multiquadrant applications. In addition, the feedback resistor (RFB) simplifies the I-to-V conversion with an external buffer. The AD5547/AD5557 are available in a compact, 38-lead TSSOP package and operate at the extended automotive temperature range of −40°C to +125°C.
评论(1)
发评论
郭wl 2021-05-31
0 回复 举报
不错的资料 收起回复
下载排行榜
全部1条评论
