AAT2510,pdf datasheet(Dual 400
消耗积分:2 | 格式:rar | 大小:221 | 2010-01-29
张生
分享资料个
The AAT2510 is a member of AnalogicTech’s Total Power Management IC™ (TPMIC™) product family. It is comprised of two 1MHz step-down converters designed to minimize external component size and cost. The input voltage ranges from 2.7V to 5.5V. The output voltage ranges from 0.6V to the maximum applied input voltage and is either fixed or externally adjustable.
评论(0)
发评论
下载排行榜
