The TPS736xx family of low-dropout (LDO) linear · Input Voltage Range of 1.7V to 5.5V voltage regulators uses a new topology: an NMOS · Ultra-Low Dropout Voltage: 75mV typ ptoapsosloegleymisensttainblae vuosltiangge-ofoultlpouwtecr acpoancfiigtourrsatiwointh. Tlohwis · Excellent Load Transient Response—with or ESR, and even allows operation without a capacitor. without Optional Output Capacitor It also provides high reverse blockage (low reverse · New NMOS Topology Delivers Low Reverse current) and ground pin current that is nearly constant Leakage Current over all values of output current. · Low Noise: 30mVRMS typ (10Hz to 100kHz) The TPS736xx uses an advanced BiCMOS process · 0.5% Initial Accuracy to yield high precision while delivering very low · 1% Overall Accuracy Over Line, Load, and dcoronpsouumtpvtoioltna,gewsheanndnlootwegnraobulnedd,piisn cuunrdreernt1. mCAurraenndt Temperature ideal for portable applications. The extremely low · Less Than 1mA max IQ in Shutdown Mode output noise (30mVRMS with 0.1mF CNR) is ideal for · Thermal Shutdown and Specified Min/Max powering VCOs. These devices are protected by Current Limit Protection thermal shutdown and foldback current limit.
