ONET8511T pdf datasheet (具有RS
消耗积分:5 | 格式:rar | 大小:777 | 2008-08-11
分享资料个
The ONET8511T is a high-speed, high linearity transimpedance amplifier used in optical receivers with data rates up to 11.3 Gbps. It features low input referred noise, 8 GHz bandwidth, 5.5 small signal transimpedance, automatic gain control (AGC) which provides highly linear operation and a received signal strength indicator (RSSI).
The ONET8511T is available in die form, includes an on-chip VCC bypass capacitor and is optimized for packaging in a TO can and for the use together with electronic dispersion compensation (EDC) ICs.
The ONET8511T requires a single +3.3 V supply and its power efficient design typically dissipates less than 160 mW. The device is characterized for operation from -25°C to 100°C (IC back side) temperature.
评论(0)
发评论
下载排行榜
