PCA9633 4位Fm+ I2C总线LED驱动器产品数据手
消耗积分:5 | 格式:rar | 大小:211 | 2010-03-08
laisvl
分享资料个
The PCA9633 is an I2C-bus controlled 4-bit LED driver optimized for
Red/Green/Blue/Amber (RGBA) color mixing applications. Each LED output has its own
8-bit resolution (256 steps) fixed frequency Individual PWM controller that operates at
97 kHz with a duty cycle that is adjustable from 0 % to 99.6 % to allow the LED to be set
to a specific brightness value. A fifth 8-bit resolution (256 steps) Group PWM controller
has both a fixed frequency of 190 Hz and an adjustable frequency between 24 Hz to once
every 10.73 seconds with a duty cycle that is adjustable from 0 % to 99.6 % that is used to
either dim or blink all LEDs with the same value.
评论(0)
发评论
下载排行榜
