AIC1748 datasheet,pdf(High PSR
消耗积分:5 | 格式:rar | 大小:459 | 2010-03-22
12268
分享资料个
AIC1748 datasheet,pdf(High PSRR, 600mA Linear Regulator With Bypass Pin)
A low noise, high PSRR and ultra low dropout linear regulator AIC1748 is optimized for low
ESR ceramic capacitors operation with 600mA continuous current. The AIC1748 is designed
for portable and wireless devices with demanding performance and space requirements.
The AIC1748 offers high precision output voltage of ±2% tolerance. Output voltage can
also be available on demand for those other than the preset values.
评论(0)
发评论
下载排行榜
