MUN5216DW1T1G pdf datasheet (D
消耗积分:2 | 格式:rar | 大小:555 | 2008-08-29
362163
分享资料个
Dual Bias Resistor Transistors
NPN Silicon Surface Mount Transistors
with Monolithic Bias Resistor Network
The BRT (Bias Resistor Transistor) contains a single transistor with
a monolithic bias network consisting of two resistors; a series base
resistor and a base−emitter resistor. These digital transistors are
designed to replace a single device and its external resistor bias
network. The BRT eliminates these individual components by
integrating them into a single device. In the MUN5211DW1T1 series,
two BRT devices are housed in the SOT−363 package which is ideal
for low power surface mount applications where board space is at a
premium.
Features
• Simplifies Circuit Design
• Reduces Board Space
• Reduces Component Count
• Pb−Free Packages are Available
评论(0)
发评论
下载排行榜
