This octal buffer and line driver is designed specifically to improve both the performance and density of 3-state memory address drivers, clock drivers, and bus-oriented receivers and transmitters. Taken together with the SN64BCT240 and SN64BCT241, these devices provide the choice of selected combinations of inverting and noninverting outputs, symmetrical active-low output-enable (
) inputs, and complementary OE and
inputs.
The SN64BCT244 is organized as two 4-bit buffers/line drivers with separate output-enable (
) inputs. When
is low, the device passes data from the A inputs to the Y outputs. When
is high, the outputs are in the high-impedance state.
The outputs are in a high-impedance state during power up and power down while the supply voltage is less than approximately 3 V.
