SN74ALVCH16244,pdf(16-BIT BUFF
消耗积分:2 | 格式:rar | 大小:632 | 2010-07-16
分享资料个
This 16-bit buffer/driver is designed for 1.65-V to 3.6-V VCC operation.
The SN74ALVCH16244 is designed specifically to improve the performance and density of 3-state memory address drivers, clock drivers, and bus-oriented receivers and transmitters.
The device can be used as four 4-bit buffers, two 8-bit buffers, or one 16-bit buffer. It provides true outputs and symmetrical active-low output-enable (OE) inputs.
To ensure the high-impedance state during power up or power down, OE should be tied to VCC through a pullup resistor; the minimum value of the resistor is determined by the current-sinking capability of the driver.
Active bus-hold circuitry holds unused or undriven inputs at a valid logic state. Use of pullup or pulldown resistors with the bus-hold circuitry is not recommended.
评论(0)
发评论
下载排行榜
