LM101A/LM201A/LM301A pdf datas
消耗积分:2 | 格式:rar | 大小:555 | 2008-09-06
分享资料个
LM101A/LM201A/LM301A Operational Amplifiers General Description
The LM101A series are general purpose operational amplifiers
which feature improved performance over industry standards
like the LM709. Advanced processing techniques
make possible an order of magnitude reduction in input
currents, and a redesign of the biasing circuitry reduces the
temperature drift of input current. Improved specifications
include:
• Offset voltage 3 mV maximum over temperature
(LM101A/LM201A)
• Input current 100 nA maximum over temperature
(LM101A/LM201A)
• Offset current 20 nA maximum over temperature
(LM101A/LM201A)
• Guaranteed drift characteristics
• Offsets guaranteed over entire common mode and supply
voltage ranges
• Slew rate of 10V/μs as a summing amplifier
This amplifier offers many features which make its application
nearly foolproof: overload protection on the input
and output, no latch-up when the common mode range is
exceeded, and freedom from oscillations and compensation
with a single 30 pF capacitor. It has advantages over
internally compensated amplifiers in that the frequency
compensation can be tailored to the particular application.
For example, in low frequency circuits it can be
overcompensated for increased stability margin. Or the
compensation can be optimized to give more than a
factor of ten improvement in high frequency performance
for most applications.
In addition, the device provides better accuracy and
lower noise in high impedance circuitry. The low input
currents also make it particularly well suited for long
interval integrators or timers, sample and hold circuits
and low frequency waveform generators. Further, replacing
circuits where matched transistor pairs buffer the
inputs of conventional IC op amps, it can give lower offset
voltage and a drift at a lower cost.
The LM101A is guaranteed over a temperature range of
−55°C to +125°C, the LM201A from −25°C to +85°C, and
the LM301A from 0°C to +70°C.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
