SN54HC241, SN74HC241,pdf(QUADR
消耗积分:3 | 格式:rar | 大小:617 | 2010-07-17
吴藩
分享资料个
These octal buffers and line drivers are designed specifically to improve both the performance and density of 3-state memory address drivers, clock drivers, and bus-oriented receivers and transmitters. The ’HC241 devices are organized as two 4-bit buffers/drivers with separate output-enable (1OE\ and 2OE) inputs. When 1OE\ is low or 2OE is high, the device passes noninverted data from the A inputs to the Y outputs. When 1OE\ is high or 2OE is low, the outputs for the respective buffers/drivers are in the high-impedance state.
评论(0)
发评论
下载排行榜
