SN74HC244-Q1,pdf(Octal Buffer
消耗积分:5 | 格式:rar | 大小:184 | 2010-07-17
李鸿洋
分享资料个
This octal buffer and line driver is designed specifically to improve both the performance and density of 3-state memory address drivers, clock drivers, and bus-oriented receivers and transmitters. The SN74HC244 is organized as two 4-bit buffers/drivers with separate output-enable (OE) inputs. When OE is low, the device passes noninverted data from the A inputs to the Y outputs. When OE is high, the outputs are in the high-impedance state.
评论(0)
发评论
下载排行榜
