LM1036 pdf,LM1036 datasheet (D
消耗积分:10 | 格式:rar | 大小:555 | 2008-09-06
分享资料个
LM1036 Dual DC Operated Tone/Volume/Balance Circuit
General Description
The LM1036 is a DC controlled tone (bass/treble), volume
and balance circuit for stereo applications in car radio, TV and
audio systems. An additional control input allows loudness
compensation to be simply effected.
Four control inputs provide control of the bass, treble, balance
and volume functions through application of DC voltages from
a remote control system or, alternatively, from four potentiometers
which may be biased from a zener regulated supply
provided on the circuit.
Each tone response is defined by a single capacitor chosen
to give the desired characteristic.
Features
■ Wide supply voltage range, 9V to 16V
■ Large volume control range, 75 dB typical
■ Tone control, ±15 dB typical
■ Channel separation, 75 dB typical
■ Low distortion, 0.06% typical for an input level of 0.3 Vrms
■ High signal to noise, 80 dB typical for an input level of 0.3
Vrms
■ Few external components required
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
