SN74GTLPH1627,pdf(18-BIT LVTTL
消耗积分:2 | 格式:rar | 大小:370 | 2010-07-24
小组店小二
分享资料个
The SN74GTLPH1627 is a high-drive, 18-bit bus transceiver that provides LVTTL-to-GTLP and GTLP-to-LVTTL signal-level translation. The device allows for transparent and latched modes of data transfer. Additionally, with the use of the clock-mode select (CMS) input, the device can be used in source synchronous and clock synchronous applications. Source synchronous applications require the skew between the clock output and data output to be minimized for optimum maximum-frequency system performance. In order to reduce this skew, aflexible setup time adjustment (FSTA) feature is incorporated into the device that sets a predetermined delay between the clock and data. The CMS and direction (DIR) inputs control the mode of the device.
评论(0)
发评论
下载排行榜
