These 18-bit flip-flops feature 3-state outputs designed specifically for driving highly capacitive or relatively low-impedance loads. They are particularly suitable for implementing wider buffer registers, I/O ports, bidirectional bus drivers with parity, and working registers.
The 'ABT16823 can be used as two 9-bit flip-flops or one 18-bit flip-flop. With the clock-enable (
) input low, the D-type flip-flops enter data on the low-to-high transitions of the clock. Taking
high disables the clock buffer, latching the outputs. Taking the clear (
) input low causes the Q outputs to go low independently of the clock.
A buffered output-enable (
) input can be used to place the nine outputs in either a normal logic state (high or low logic level) or a high-impedance state.
