SN74AVCH4T245,pdf(4-Bit Dual-S
消耗积分:3 | 格式:rar | 大小:893 | 2010-08-22
贾伟刚
分享资料个
16-BIT DUAL-SUPPLY BUS TRANSCEIVER
FEATURES
• Control Inputs V IH /V IL Levels Are Referenced
to V CCA Voltage
• Fully Configurable Dual-Rail Design Allows
Each Port to Operate Over the Full 1.2-V to
3.6-V Power-Supply Range
• I/Os Are 4.6-V Tolerant
• I off Supports Partial Power-Down-Mode
Operation
• Bus Hold on Data Inputs Eliminates the Need
for External Pullup/Pulldown Resistors
• Max Data Rates
– 380 Mbps (1.8V to 3.3V Translation)
– 200 Mbps ( <1.8V to 3.3V Translation)
– 200 Mbps (Translate to 2.5V or 1.8V)
– 150 Mbps (Translate to 1.5V)
– 100 Mbps (Translate to 1.2V)
• Latch-Up Performance Exceeds 100 mA Per
JESD 78, Class II
• ESD Protection Exceeds JESD 22
– 8000-V Human-Body Model (A114-A)
– 200-V Machine Model (A115-A)
– 1000-V Charged-Device Model (C101)
评论(0)
发评论
下载排行榜
