LM2462 pdf,LM2462 datasheet
消耗积分:3 | 格式:rar | 大小:555 | 2008-09-19
贾小龙
分享资料个
LM2462 Monolithic Triple 3 ns CRT Driver General Description
The LM2462 is an integrated high voltage CRT driver circuit
designed for use in color monitor applications. The IC contains
three high input impedance, wide band amplifiers
which directly drive the RGB cathodes of a CRT. Each
channel has its gain internally set to −20 and can drive CRT
capacitive loads as well as resistive loads present in other
applications, limited only by the package’s power dissipation.
The IC is packaged in an industry standard 11-lead TO-220
molded plastic power package. See Thermal Considerations
section.
评论(0)
发评论
下载排行榜
