SN751701,pdf(Line Driver and R
消耗积分:3 | 格式:rar | 大小:409 | 2010-09-02
罗星
分享资料个
The SN751701 line driver and receiver is designed to satisfy the requirements of the standard interface between data terminal equipment and data communication equipment as defined by ANSI TIA/EIA-232-E. The driver used is similar to the SN75188. The receiver used is similar to the SN75189A. The device operates over a wide range of supply voltages (VCC = ±4.5 V to ±15 V) from the included reference regulator.
评论(0)
发评论
下载排行榜
