EL5262, EL5263,EL5362 pdf data
消耗积分:5 | 格式:rar | 大小:666 | 2008-09-21
打马过草原
分享资料个
The EL5162, EL5163, EL5262, EL5263, and EL5362 are current feedback amplifiers with a bandwidth of 500MHz. This makes these amplifiers ideal for today’s high speed video and monitor applications.
With a supply current of just 1.5mA and the ability to run from a single supply voltage from 5V to 12V, these amplifiers are also ideal for handheld, portable or battery-powered equipment.
The EL5162 also incorporates an enable and disable function to reduce the supply current to 100μA typical per amplifier. Allowing the CE pin to float or applying a low logic level will enable the amplifier.
The EL5162 is available in 6 Ld SOT-23 and 8 Ld SOIC packages, the EL5163 in 5 Ld SOT-23 and SC-70 packages, the EL5262 in the 10 Ld MSOP package, the EL5263 in 8 Ld MSOP and SO packages, and the EL5362 in 16 Ld SOIC (0.150”) and QSOP packages. All operate over the industrial temperature range of -40°C to +85°C.
评论(0)
发评论
下载排行榜
