THS7327,pdf(3-Ch RGBHV Video B
消耗积分:5 | 格式:rar | 大小:855 | 2010-09-27
分享资料个
Fabricated using the new complementary silicon-germanium (SiGe) BiCom-III process, the THS7327 is a low-power, single-supply 2.7-V to 5-V, 3-channel integrated video buffer with H and V Sync signal paths. It incorporates a selectable 5th order Butterworth anti-aliasing filter on each channel. The 9-MHz is a perfect choice for SDTV video including composite, S-Video, and 480i/576i. The 16-MHz filter is ideal for EDTV 480p/576p and VGA signals. The 35-MHz filter is useful for HDTV 720p/1080i and SVGA signals. The 75-MHz filter is ideal for HDTV 1080p and XGA/SXGA signals. For UXGA/QXGA R'G'B' signals, the filter can be bypassed allowing a 500-MHz bandwidth, 1150-V/µs amplifier to buffer the signal.
Each channel of the THS7327 is individually I2C configurable for all functions including controlling the 2:1 input MUX.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
