TLV7101828,pdf(Dual, 200mA, Lo
消耗积分:3 | 格式:rar | 大小:1274 | 2010-10-21
分享资料个
The TLV710 and TLV711 series of dual, low-dropout (LDO) linear regulators are low quiescent current devices with excellent line and load transient performance. These LDOs are designed for power-sensitive applications. These devices provide a typical accuracy of 2% over temperature.
The TLV711 series provides an active pulldown circuit to quickly discharge the outputs.
In addition, the TLV711-D series of devices have pull-down resistors at the EN pins. This design helps in disabling the device when the signal-driving EN pins are in a weak, indeterminate state (for example, the GPIO of a processor that might be three-stated during startup). The pull-down resistor pulls the voltage to the EN pins down to 0V, thus disabling the device.
评论(0)
发评论
下载排行榜
