The TPS2458 AdvancedMC™ slot controller is fully compliant with the AdvancedMC™ Standard and provides the required accuracy to meet the demands of an AdvancedMC™ (Advanced Mezzanine Card) module.
The TPS2458 is an extremely flexible solution that protects both the power supply and the load by limiting the maximum current into the load and shutting off in case of a fault. If a severe fault occurs the current shuts off immediately.
Optional ORing support is inherent in the architecture and can be used in MicroTCA™, or other applications requiring ORing support.
The 3.3-V management channel is internal and requires only one external resistor for load monitoring and one external capacitor to set fault time.
下载资料需要登录,并消耗一定积分。
