TPS65193,pdf(Dual High-Voltage
消耗积分:2 | 格式:rar | 大小:460 | 2010-11-03
李鸿洋
分享资料个
The TPS65193 is dual high-voltage scan driver to drive an amorphous-silicon-gate (ASG) circuit on TFT glass.
Each single high-voltage scan driver receives logic-level inputs of CPVx and generates two high-voltage outputs
of CKVx and CKVBx. The device receives a logic-level input of STV and generates a high-voltage output of
STVP. These outputs are swings from Voff (–28 V) to Von (35 V) and are used to drive the ASG circuit and
charge/discharge the capacitive loads of the TFT LCD. In order to reduce the power dissipation of the device, a
charge-share function is implemented. The device features a discharge function, which shorts Voff to GND in
order to shut down the panel faster when the LCD is turned off.
评论(0)
发评论
下载排行榜
