FEATURES ● High Current Capability 1.5A ● Low Dropout Voltage 350mV ● Low Ground Current ● Accurate 1% Cuaranteed Tolerance ● Extremely Fast Transient Response ● Reverse-Battery and "Load Dump" Rotection ● Zero-Current Shutdown Mode(5-Pin Version) ● Error Flag Signals Output out-of-Regulation (5-Pin Versions) ● Also Characterized For Smaller Loads With Industry -Leading Performance specifications ● Fixed Voltage and Adjustable Versions APPLICATIONS ● Battery Powered Equipment ● High-Efficiency " Green" Computer System ● Automotive Electronics ● High-Efficiency Linear Power Supplies ● High-Efficiency Post-Regulator For Switching Supply
