ADS8320 pdf datasheet (16-Bit,
消耗积分:5 | 格式:rar | 大小:333 | 2008-12-18
分享资料个
The ADS8320 is a 16-bit sampling analog-to-digital
converter (A/D) with guaranteed specifications over a
2.7V to 5.25V supply range. It requires very little
power even when operating at the full 100kHz data
rate. At lower data rates, the high speed of the device
enables it to spend most of its time in the power-down
mode—the average power dissipation is less than
100mW at 10kHz data rate.
The ADS8320 also features operation from 2.0V to
5.25V, a synchronous serial (SPI/SSI compatible) interface,
and a differential input. The reference voltage
can be set to any level within the range of 500mV to
VCC.
Ultra-low power and small size make the ADS8320
ideal for portable and battery-operated systems. It is
also a perfect fit for remote data acquisition modules,
simultaneous multi-channel systems, and isolated
data acquisition. The ADS8320 is available in
an MSOP-8 package.
评论(0)
发评论
下载排行榜
