HA2546/883 pdf datasheet(Wideb
消耗积分:3 | 格式:rar | 大小:715 | 2008-12-23
h1654155275.0032
分享资料个
Features
• This Circuit is Processed in Accordance to MIL-STD-
883 and is Fully Conformant Under the Provisions of
Paragraph 1.2.1.
• High Speed Voltage Output. . . . . . . . . . . .300V/μs (Min)
• Low Multiplication Error . . . . . . . . . . . . . . . .3.0% (Max)
1.6% (Typ)
• Input Bias Currents . . . . . . . . . . . . . . . . . . . . .5μA (Max)
1.2μA (Typ)
• Signal Input Feedthrough . . . . . . . . . . . . . . -52dB (Typ)
• Wide Signal Bandwidth . . . . . . . . . . . . . . . 30MHz (Typ)
• Wide Control Bandwidth . . . . . . . . . . . . . . 17MHz (Typ)
• Gain Flatness to 5MHz. . . . . . . . . . . . . . . . 0.10dB (Typ)
Applications
• Military Avionics
• Missile Guidance Systems
• Medical Imaging Displays
• Video Mixers
• Sonar AGC Processors
• Radar Signal Conditioning
• Voltage Controlled Amplifier
• Vector Generator
评论(0)
发评论
下载排行榜
