ICL8013 pdf datasheet(1MHz, Fo
消耗积分:3 | 格式:rar | 大小:555 | 2009-01-06
吴湛
分享资料个
The ICL8013 is a four quadrant analog multiplier whose
output is proportional to the algebraic product of two input
signals. Feedback around an internal op amp provides level
shifting and can be used to generate division and square
root functions. A simple arrangement of potentiometers may
be used to trim gain accuracy, offset voltage and
feedthrough performance. The high accuracy, wide
bandwidth, and increased versatility of the ICL8013 make it
ideal for all multiplier applications in control and
instrumentation systems. Applications include RMS
measuring equipment, frequency doublers, balanced
modulators and demodulators, function generators, and
voltage controlled amplifiers.
评论(0)
发评论
下载排行榜
