HA-5101 pdf datasheet(10MHz, L
消耗积分:2 | 格式:rar | 大小:355 | 2009-01-07
分享资料个
The HA-5101 is a dielectrically isolated operational amplifier
featuring low noise, (3.0nV/√Hz at 1kHz).
DC characteristics of the HA-5101 assure accurate
performance. The 0.5mV offset voltage is externally adjustable
and offset voltage drift is just 3μV/oC. An offset current
of only 30nA reduces input current errors and an open loop
voltage gain of 1 x 106V/V increases loop gain for low
distortion amplification.
The HA-5101 is ideal for audio applications, especially lowlevel
signal amplifiers such as microphone, tape head and
phono cartridge preamplifiers. Additionally, it is well suited
for low distortion oscillators, low noise function generators
and high Q filters.
评论(0)
发评论
下载排行榜
