HA-5102, HA-5104 pdf datasheet
消耗积分:3 | 格式:rar | 大小:444 | 2009-01-08
李艳
分享资料个
Low noise and high performance are key words describing
HA-5102 and HA-5104. These general purpose amplifiers
offer an array of dynamic specifications including a 3V/μs
slew rate and 8MHz bandwidth. Complementing these
outstanding parameters is a very low noise specification of
4.3nV/√Hz at 1kHz.
Fabricated using the Intersil high frequency DI process,
these operational amplifiers also offer excellent input
specifications such as a 0.5mV offset voltage and 30nA
offset current. Complementing these specifications are
108dB open loop gain and 60dB channel separation.
Consuming a very modest amount of power (90mW/
package for duals and 150mW/package for quads),
HA-5102/04 also provide 15mA of output current.
This impressive combination of features make this series of
amplifiers ideally suited for designs ranging from audio
amplifiers and active filters to the most demanding signal
conditioning and instrumentation circuits.
These operational amplifiers are available in dual or quad
form with industry standard pinouts allowing for immediate
interchangeability with most other dual and quad operational
amplifiers.
HA-5102 Dual, Comp. HA-5104 Quad, Comp.
Refer to the /883 data sheet for military product.
评论(0)
发评论
下载排行榜
