The EL5191 and EL5191A amplifiers are of the current feedback variety and exhibit a very high bandwidth of 1GHz. This makes these amplifiers ideal for today’s high speed video and monitor applications, as well as a number of RF and IF frequency designs. With a supply current of just 9mA and the ability to run from a single supply voltage from 5V to 10V, these amplifiers offer very high performance for little power consumption. The EL5191A also incorporates an enable and disable function to reduce the supply current to 100μA typical per amplifier. Allowing the CE pin to float or applying a low logic level will enable the amplifier. The EL5191 is offered in the 5 Ld SOT-23 package and the industry-standard 8 Ld SOIC package. EL5191A is available in the industry-standard 8 Ld SOIC package. Both operate over the industrial temperature range of -40°C to +85°C.
