LTC2053资料
消耗积分:0 | 格式:pdf | 大小:245 KB | 2011-08-30
分享资料个
The LTC®2053 is a high precision instrumentation amplifier.The CMRR is typically 116dB with a single or dual 5V supply with any programmed gain including unity. The offset is guaranteed below 10mV with a temperature drift of less than 50nV/°C. The LTC2053 is easy to use; the gain is adjustable with two external resistors, like a traditional op amp.
评论(0)
发评论
下载排行榜
