MAX97220A,MAX97220B,MAX97220C,MAX97220D
消耗积分:0 | 格式:pdf | 大小:1.6 MB | 2011-10-26
分享资料个
The MAX97220_ is a differential input DirectDrive® linedriver/headphone amplifier. This device is capable ofdriving line level loads with 3VRMS into 1kI with a 5Vsupply and 2VRMS into 600I loads from a 3.3V supply. Aheadphone load is capable of being driven with 125mWinto 32I with a 5V supply. The IC is offered with an internallyfixed 6dB gain or an externally set gain throughexternal resistors. The external gain setting nodes canbe used to configure filters for set-top box applications.The IC has exceptional THD+N over the full audio
bandwidth.
评论(0)
发评论
下载排行榜
