MM54HC00 MM74HC00 pdf
消耗积分:0 | 格式:pdf | 大小:71.0 KB | 2011-11-15
分享资料个
These NAND gates utilize advanced silicon-gate CMOS technology to achieve operating speeds similar to LS-TTL gates with the low power consumption of standard CMOS integrated circuits. All gates have buffered outputs. All devices have high noise immunity and the ability to drive 10 LS-TTL loads. The 54HC/74HC logic family is functionally as well as pin-out compatible with the standard 54LS/74LS
logic family. All inputs are protected from damage due to static discharge by internal diode clamps to VCC and ground.
评论(0)
发评论
下载排行榜
