The MAX16904 is a small, synchronous buck converterwith integrated high-side and low-side switches. Thedevice is designed to deliver 600mA with input voltagesfrom +3.5V to +28V while using only 25μA quiescentcurrent at no load. Voltage quality can be monitored byobserving the PGOOD signal. The MAX16904 can operatein dropout by running at 97% duty cycle, making itideal for automotive and industrial applications.
