The MAX13020/MAX13021 ±60V fault-protected low-power local interconnect network (LIN) transceivers are ideal for use in automotive network applications where high reliability is required. The devices provide the interface between the LIN master/slave protocol controller,and the physical bus described in the LIN 2.0 specification package and SAE J2602 specification.The devices are intended for in-vehicle subnetworks with a single master and multiple slaves.
