LM3477,pdf datasheet (High Eff
消耗积分:3 | 格式:rar | 大小:551 | 2009-09-28
哈哈哈
分享资料个
The LM3477/A is a high-side N-channel MOSFET switching
regulator controller. It can be used in topologies requiring a
high side MOSFET such as buck, inverting (buck-boost) and
zeta regulators. The LM3477/A’s internal push pull driver
allows compatibility with a wide range of MOSFETs. This, the
wide input voltage range, use of discrete power components
and adjustable current limit allows the LM3477/A to be optimized
for a wide variety of applications.
评论(0)
发评论
下载排行榜
