LM3485/LM3485Q,pdf datasheet (
消耗积分:3 | 格式:rar | 大小:554 | 2009-09-28
吴湛
分享资料个
The LM3485 is a high efficiency PFET switching regulator
controller that can be used to quickly and easily develop a
small, low cost, switching buck regulator for a wide range of
applications. The hysteretic control architecture provides for
simple design without any control loop stability concerns using
a wide variety of external components. The PFET architecture
also allows for low component count as well as ultralow
dropout, 100% duty cycle operation. Another benefit is
high efficiency operation at light loads without an increase in
output ripple.
评论(0)
发评论
下载排行榜
