LM20134,pdf datasheet (Synchro
消耗积分:2 | 格式:rar | 大小:551 | 2009-09-28
靓仔峰
分享资料个
The LM20134 is a full featured synchronous buck regulator
capable of delivering up to 4A of continuous output current.
The current mode control loop can be compensated to be
stable with virtually any type of output capacitor. For most
cases, compensating the device only requires two external
components, providing maximum flexibility and ease of use.
The device is optimized to work over the input voltage range
of 2.95V to 5.5V making it suited for a wide variety of low voltage
systems.
评论(0)
发评论
下载排行榜
