LM8262,pdf datasheet (RRIO, Hi
消耗积分:3 | 格式:rar | 大小:554 | 2009-10-07
370217
分享资料个
The LM8262 is a Rail-to-Rail input and output Op Amp which
can operate with a wide supply voltage range. This device
has high output current drive, greater than Rail-to-Rail input
common mode voltage range, unlimited capacitive load drive
capability, and provides tested and guaranteed high speed
and slew rate. It is specifically designed to handle the requirements
of flat panel TFT panel VCOM driver applications
as well as being suitable for other low power, and medium
speed applications which require ease of use and enhanced
performance over existing devices.
评论(0)
发评论
下载排行榜
