LM160/LM360,pdf datasheet (Hig
消耗积分:3 | 格式:rar | 大小:551 | 2009-10-08
麻酱
分享资料个
The LM160/LM360 is a very high speed differential input,
complementary TTL output voltage comparator with improved
characteristics over the μA760/μA760C, for which it
is a pin-for-pin replacement. The device has been optimized
for greater speed, input impedance and fan-out, and lower
input offset voltage. Typically delay varies only 3 ns for
overdrive variations of 5 mV to 400 mV.
评论(0)
发评论
下载排行榜
