LM161/LM361,pdf datasheet (Hig
消耗积分:5 | 格式:rar | 大小:551 | 2009-10-08
goodmbby
分享资料个
The LM161/LM361 is a very high speed differential input,
complementary TTL output voltage comparator with improved
characteristics over the SE529/NE529 for which it is
a pin-for-pin replacement. The device has been optimized for
greater speed performance and lower input offset voltage.
Typically delay varies only 3 ns for over-drive variations of 5
mV to 500 mV. It may be operated from op amp supplies
(±15V).
评论(0)
发评论
下载排行榜
