74HC/HCT4316 pdf datasheet
消耗积分:3 | 格式:rar | 大小:333 | 2008-07-14
分享资料个
The 74HC/HCT4316 are high-speed Si-gate CMOS
devices. They are specified in compliance with JEDEC
standard no. 7A. The 74HC/HCT4316 have four independent analog
switches. Each switch has two input/output terminals
(nY, nZ) and an active HIGH select input (nS). When the
enable input (E) is HIGH, all four analog switches are
turned off.
Current through a switch will not cause additional VCC
current provided the voltage at the terminals of the switch
is maintained within the supply voltage range;
VCC >> (VY, VZ) >> VEE. Inputs nY and nZ are electrically
equivalent terminals.
VCC and GND are the supply voltage pins for the digital
control inputs (E and nS). The VCC to GND ranges are 2.0
to 10.0 V for HC and 4.5 to 5.5 V for HCT.
The analog inputs/outputs (nY and nZ) can swing between
VCC as a positive limit and VEE as a negative limit.
VCC − VEE may not exceed 10.0 V.
See the “4016” for the version without logic level
translation.
评论(0)
发评论
下载排行榜
