500ma可变/固定输出 LDO稳压器BD18KA5WF-E2
消耗积分:0 | 格式:rar | 大小:0.67 MB | 2017-08-31
分享资料个
  General Description The BDxxKA5 series are low-saturation regulators that are available for output currents up to 500mA. The output voltage precision is ±1%. These LDO regulators are offered in several output voltages and package lineups with or without ON/OFF switches (that set the circuit current to 0μA at shutdown)。 This series can be used for a broad spectrum of applications ranging from TVs and car audio systems to HDDs, PCs, and DVDs. There regulators have a built-in overcurrent protection circuit that prevents the destruction of the IC, due to output short circuits and a thermal shutdown circuit.
  Features „ Output voltage precision: ±1% „ Low-saturation voltage with PMOS output: 0.12V Typ.(Io=200mA) „ Built-in over-current protection circuit „ Built-in thermal shutdown circuit „ Shutdown switch (BDxxKA5WFP and BDxxKA5WF series) „ Ceramic capacitor compatible (recommended capacitance: 1μF or greater) ●Key Specifications „ Input Power Supply Voltage: 5.5V (Max.) „ Output voltage type: BA00KA5 Variable BAxxKA5 Fixed „ Output current: 500mA (Max.) „ Operating temperature range: -40℃ to +105℃ ●Applications Microcontrollers and all electronic devices that use logic circuit
评论(0)
发评论
下载排行榜
