Description The AMIS−42670 CAN transceiver is the interface between a controller area network (CAN) protocol controller and the physical bus and may be used in both 12 V and 24 V systems. The transceiver provides differential transmit capability to the bus and differential receive capability to the CAN controller. Due to the wide common−mode voltage range of the receiver inputs, the AMIS−42670 is able to reach outstanding levels of electromagnetic susceptibility (EMS). Similarly, extremely low electromagnetic emission (EME) is achieved by the excellent matching of the output signals. The AMIS−42670 is the industrial version of the AMIS−30660 and primarily intended for applications where long network lengths are mandatory. Examples are elevators, in−building networks, process control and trains. To cope with the long bus delay the communication speed needs to be low. AMIS−42670 allows low transmit data rates down 10 kbit/s or lower.
