The NCV898031 is an adjustable output non−synchronous 2 MHz SEPIC/boost controller which drives an external N−channel MOSFET. The device uses peak current mode control with internal slope compensation. The IC incorporates an internal regulator that supplies charge to the gate driver. Protection features include internally−set soft−start, undervoltage lockout, cycle−by−cycle current limiting and thermal shutdown. Additional features include low quiescent current sleep mode and microprocessor compatible enable pin.
