14位AD7946模数转换器500kSPS的脉冲星在MSOP和LFCSP数据表
消耗积分:0 | 格式:rar | 大小:0.58 MB | 2017-10-10
分享资料个
  The AD79461 is a 14-bit, charge redistribution, successive approximation, analog-to-digital converter (ADC) that operates from a single 5 V power supply, VDD. It contains a low power, high speed, 14-bit sampling ADC with no missing codes, an internal conversion clock, and a versatile serial interface port. The part also contains a low noise, wide bandwidth, short aperture delay track-and-hold circuit. On the CNV rising edge, it samples an analog input IN+ between 0 V to REF with respect to a ground sense IN−。 The reference voltage, REF, is applied externally and can be set up to the supply voltage. Its power scales linearly with throughput. The SPI-compatible serial interface also features the ability, using the SDI input, to daisy-chain several ADCs on a single, 3-wire bus, or it provides an optional BUSY indicator. It is compatible with 1.8 V, 2.5 V, 3 V, or 5 V logic, using the separate supply VIO. The AD7946 is housed in a 10-lead MSOP or a 10-lead LFCSP with operation specified from −40°C to +85°C.
评论(1)
发评论
jianeee 2018-05-08
0 回复 举报
假的,就是一个datasheet 收起回复
下载排行榜
全部1条评论
