TC1263 pdf datasheet
消耗积分:3 | 格式:rar | 大小:444 | 2008-08-07
吴湛
分享资料个
The TC1263 is a fixed-output, high-accuracy (typically
±0.5%) CMOS low dropout regulator. Designed
specifically for battery-operated systems, the TC1263’s
CMOS construction eliminates wasted ground current,
significantly extending battery life. Total supply current
is typically 80 μA at full load (20 to 60 times lower than
in bipolar regulators).
TC1263 key features include ultra low noise operation,
very low dropout voltage (typically 350 mV at full load)
and fast response to step changes in load.
The TC1263 incorporates both overtemperature and
overcurrent protection. The TC1263 is stable with an
output capacitor of only 1 μF and has a maximum
output current of 500 mA. It is available in 8-Pin SOIC,
5-Pin TO-220 and 5-Pin DDPAK packages.
评论(0)
发评论
下载排行榜
