ADS7883 pdf datasheet (12-Bit,
消耗积分:3 | 格式:rar | 大小:888 | 2008-08-19
李鸿洋
分享资料个
The ADS7883 is a 12-bit, 3-MSPS analog-to-digital converter (ADC). The device includes a capacitor based SAR
A/D converter with inherent sample and hold. The serial interface in the device is controlled by the CS and SCLK
signals for glueless connections with microprocessors and DSPs. The input signal is sampled with the falling
edge of CS, and SCLK is used for conversion and serial data output.
The device operates from a wide supply range from 2.7 V to 5.5 V. The low power consumption of the device
makes it suitable for battery-powered applications. The device also includes a power saving power-down feature
for when the device is operated at lower conversion speeds.
The high level of the digital input to the device is not limited to device VDD. Therefore the digital input can go as
high as 5.5 V when the device supply is 2.7 V. This feature is useful when digital signals are received from
another circuit with different supply levels. This also reduces restrictions on power-up sequencing.
The ADS7883 is available in a 6-pin SOT23 package and is specified for operation from –40°C to 125°C.
评论(0)
发评论
下载排行榜
